2004 C5 Intake
Old Feb 8, 2006 | 02:19 PM
harleypdd's Avatar
harleypdd
Default 2004 C5 Intake
I've been looking to purchase an aftermarket intake system (Y-shaped Dual Pipe System) for my 2004 C5. I've been looking on ebay, but mostly what I find says for 97-00 vettes. What is the difference, if any, between those years and 01-04? Will these not work on mine? Any input would be appreciated.
Old Feb 8, 2006 | 03:23 PM
SynistrC5's Avatar
SynistrC5
was 01 the year that gm went to the larger MAF?
Old Feb 8, 2006 | 05:00 PM
sage666's Avatar
sage666
There is no aftermarket intake system that will provide significant power increase below 5000RPM. K&N is the only maker that states on their web site that their intake kit makes 11+HP at 5400RPM. So, basically, other than looks, such kits are worthless for a daily driver.
Old Feb 8, 2006 | 10:46 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Good air intake systems are good for everyday
Yes, the MAF is slightly larger on the 2001 to 2004, both LS1 and ZO6. I have to disagree with sage666, most of the air intake systems make 10-15 HP at much lower rpms. Many of the systems do make more HP as the cars spped increases.
IMHO
Clayton
Old Feb 9, 2006 | 11:40 AM
harleypdd's Avatar
harleypdd
ttt
Old Feb 9, 2006 | 12:14 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I'm in the office so going by memory here, but I think the following were the major changes:
In 2001 there were several intake changes. A completely new higher flowing Intake Manifold, larger MAFS (from 74 mm to I think 85 mm), TB stayed the same at 74 mm. Also, incorporated the IAT (inlet air temp) sensor into the MAFS. On the 97-2000 intakes the IAT is a seperate component mounted in the aft end of the air bridge near the TB.
Hope this helps, others may have a better memory than I do.
To 2004 C5 Intake
