Well after pulling my motor yesterday. Putting in the stupid litle plug in the oil galley at the back of the block. I slid the motor back on the torque tube and bolted the subassembly back up tonight. For the second time in 1 week Getting pretty good at it though. So i will be turning the key tomorow night and lets hope this time i will be posting a sound clip and not a what not to do post. I am heading off for a good nights rest. Everyone wish me luck tomorow.
Good Luck!! Before you turn that key I would just check the grounds again. There was a fella not but a week or so ago that swapped engines, put it all back together, turned the key and basically no to much happened. Turned out, it was a ground he forgot to bolt up. These things and their grounds!! but good luck, hope she fires right up!!!
Hmmmmm that guy sounds like ....... <------ yeh these things and their grounds and stupid litle oil gally plugs
live n learn. I email you some pics of her stripped down, patience young grasshoppa !
had it started.. got 50 psi o oil press at idle way cooler than 10 ( stupid litle plug).. Doesnt wanna idle that well now that the lifters have pumped up and getting all the lift i should. sounds f'in WICKED.. like it almost takes my breath away I have the batery on charge now cause it died earlier.. im gonna bring it up to operating temp tonight. drop the oil out of it change the oil filter. and then finish everything up tomorow and take her for her maiden cruise
