tire question, needs quick reply before paying ebay
i have an 18x10.5 motorsport wheel, will a tire size of 295 30 18 be a problem as far as the car being too heavy? the ad says max load 1447 lbs thanks for the quick reply.
A 295mm width tire size will "work" on an 10.5 inch wide width wheel. However, an 305mm tire size is a more appropriate tire width size for a 10.5 inch wide wheel. Good luck to you.
the only thing to worry about with that tire is the outer diameter being to small. w/o looking it up I'm not sure how far off it is, but a 295/35-18 (OEM Size for the Z06) would be better.
If you outer diameter of the tire is smaller than the front tire you could have problems with the TC and AH, and the speedometer will be off a little unless you reprogram it, but I'm not sure w/o looking it up.
