seat problems, need help
Old Feb 9, 2006 | 03:53 PM
topless99's Avatar
topless99
Default seat problems, need help
Drivers side lumbar and bolsters quit. Forward, back and up,down still work. Passenger seat still works fine. Any quick and easy ways to check what happened before i pull the seat? Thanks for any replies.
Old Feb 9, 2006 | 04:06 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
there is a relay box under the lower seat cushion, can you hear the pumps working? is the bladder leaking? i'd try to swap the relay box from L to R, it only takes a few minutes to remove the seats
Old Feb 9, 2006 | 04:09 PM
SteveDoten's Avatar
SteveDoten
just realized your in Mass, i have a c5 w/ sport seats if you need to borrow the relay for troubleshooting, also have the switch removed
Old Feb 9, 2006 | 04:20 PM
topless99's Avatar
topless99
nothing at all happens when i hit the switches. no click, whir, buzz nothing at all. Now for an even stupider question. How do you get the little plastic covers off the front bolts without breaking them to get the seat off?
Old Feb 9, 2006 | 06:11 PM
00247's Avatar
00247
There is a round headed fastener on the front of the plastic trim piece. Pull the round head of the pin out. The fastener will then disengage and the trim piece will come right off!
Old Feb 9, 2006 | 06:22 PM
SteveDoten's Avatar
SteveDoten
www.vetteessentials.com , ck out the seat cover install link
Old Feb 9, 2006 | 07:42 PM
topless99's Avatar
topless99
thanks, i was scared to just pull the pin in case it wasnt just a pull out deal.
Old Feb 9, 2006 | 08:14 PM
gonbad's Avatar
gonbad
I had a similar problem. Replaced the switch and that didn't fix the problem. It was the harness under the seat was cracked and created a short. Had the dealership fix it. One of the few items I have had the dealership fix since the warranty ran out.
Old Feb 10, 2006 | 12:33 PM
NCOMNC5's Avatar
NCOMNC5
Default same problem here
stupid me, I've had and still have that problem after purchasing a second set of seats. The original drive seat is worn on the bloster and I couldn't pass up the price for the second set after tech told me the module was bad and would cost about $800 to replace it. So now I have original set covered up in a nice dry spot in the house for a little over 2 years...
Old Feb 11, 2006 | 02:24 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
As the others have said, just pop that pin towards the front of the vehicle. DO NOT pull straight up on the covers, They are hooked in on the front of the plastric trim as well. Once the pin is removed, push forward on the bezels. Just wiggle them side to side while pushing forward. Once you get them off you will see where if you pull them straight up, they could break.
Old Feb 12, 2006 | 03:30 PM
BanditSRT's Avatar
BanditSRT
My bolsters quit too...
To seat problems, need help
