Wierd problem with history...
Old Feb 9, 2006 | 08:05 PM
dsmboosted's Avatar
dsmboosted
Default Wierd problem with history...
Ok, I have been having some wierd problems with my 97 c5. They are as follows:
-I was driving down the freeway one day and went to pass a car, and my car said reduced engine power in the display and I had almost no power so I pulled over. I turned the car off for about 5 minutes and the preoblem went away and never returned.
-A few months later (present time)...every once in a while (mainly when I hit a bump in the road) the car display puts up an error that says the abs, and traction system are not working.
-every once in a while (every 5-15 days) the fuel gauge will completely turn off and go to "E" even if its at a full tank. It will do this for seemingly no reason. Then it will "magically" function corectly, sometimes during the same car ride or sometimes after the car is turned on and off a few times.
Are any of these events related??? does anyone have any idea what is going on???? Do i need to call an excorcist on my car??? Please help!!
Old Feb 9, 2006 | 08:24 PM
dpd's Avatar
dpd
make sure all your grounds are CLEAN and TIGHT! same with all your power connections.
1]reduced power-if you had a leaking battery,pull the right front fender inner well and look at the tac and pcm harnesses.you want to make sure they are not corroded including the connectors.the ground for the pcm,bcm,ipc,sdm comes out of that harness and bolts to the block.early cars also suffer from flukey tac controllers.next time it happens,get the fault it stores.
2]abs/traction- look at the harnesses and extension harnesses on each wheel.the pins like to spread and create intermittant connections as the control arms move.this is also common on early year cars as the later cars run the newer type terminals,but even then the newer cars can still suffer from it.once again,when it happens grab the faults.
3]fuel gauge-go get a bottle of techron and on your next fill up,dump it in,run the car down,then on the next fill up,use a half bottle.more than likely it will be back to normal.
JMO
Old Feb 9, 2006 | 08:46 PM
dsmboosted's Avatar
dsmboosted
when you say grab the fault, do you mean the codes it throws in the ecu?
Also, the techron, is that like a fuel injection cleaner? How will the techron help?
Thank you for your reply.
Old Feb 9, 2006 | 10:56 PM
dataporter's Avatar
dataporter
Seems like I saw a thread here that said you may need to find and clean all the grounds. IE where the electrical system is grounded to the chassis. Here check this out!
http://forums.corvetteforum.com/showthread.php?t=896875
Old Feb 9, 2006 | 11:05 PM
turboc5's Avatar
turboc5
Techron is fuel system cleaner. The fuel gauge problem is due to a dirty sending unit. The chevron techron is the best for this but you can try others if you can't find techron. This problem is quite common with c5's
To Wierd problem with history...
