i have american racing headers, by vette doc
hi flow cats, borla exhaust
blackwing air filter.
i want about 410-450 rwhp.
the car is not a daily driver. however, i live in NYC and there is a lot of traffic. so i can t go w/ a big cam. I dont run on the track, but I do want HP.
1) what size heads should i go w/
2) what cam
3) Should i go w/ fast intake 90 mm?
4) will i need a clutch
Very easy to run with no surging. that will produce around 416 rwhp.
If you want something more aggressive then the G5X3 is great. I have that with AFR heads and it is not bad in traffic. that will put you in the 450 range with stock gears.
You will probably not need a new clutch with 416 rwhp but you will with 450 rwhp.
you could also wait a bit and see how the tuners do with the ETP heads that they are trying now. Results should be posted soon by some local tuners.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
See my sig. My cam may be a little too big if you drive in heavy traffic, but you could go one step smaller and still get good H/P #'s. I love the GM Performance Parts heads and they only run about $2,100. My tuner was suprised at the power they made and they are very close to stock compression ratios.
