I am doing a heads and cam install and I am just going to keep the emissions stuff off. On my 2000 there are some tubes that go to my headers and I know that you can get some plates to block them off, does anyone know where I can get them? Ordering them online is not really an option.
I would reccomend cutting the tubes off and welding shut. Some have had problems with the necks breaking off when using a blocking plate. I just made some blocks for mine until I get them cut and welded.
i welded mine when i had them off for the motor swap... pm me you gotta here my car now!! if the headers are in charleston ill swing by with my wire feed and weld those pesky litle things shut for you
It ain't necessary, I kept everything on right now and I have the part number from thunderracing.com (thanks englandgreen).
