Ported Cylinder Heads
Old Feb 13, 2006 | 12:40 AM
mrsaud's Avatar
mrsaud
Default Ported Cylinder Heads
Hey Guys ,
I have got C6 '06 A6 , and I am thinking of getting Ported Cylinder Heads + Headers with Borla Exhaust System .
I need a site which I can order Ported Cylinder Heads + Headers , and I want to know which is the best to be on my car .
Finally with all those parts how many Hp do you think the car will be ?
Thanks alot .
Old Feb 13, 2006 | 01:05 AM
Mitch C's Avatar
Mitch C
Originally Posted by mrsaud
Hey Guys ,
Thanks alot .
For the best results with ported heads you should consider going to a bigger cam, to get the full benefit of ported heads & headers. I would also consider going to a higher stalling converter if they are available for the new A6 tranny.
Old Feb 13, 2006 | 02:25 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
they dont call it "heads and cam" for nothing.
Old Feb 13, 2006 | 02:58 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Hey Guys ,
Thanks alot .
AFR 205's or Edlebrock 215s' both are great flowing with high velocity runners. Also, bolt on a set of LG headers and for some added kick, our A&A AX3 cam.
CHarlie
Old Feb 13, 2006 | 10:32 AM
mdhmi's Avatar
mdhmi
AX3 cam?
Mark
Old Feb 13, 2006 | 01:05 PM
95jersey's Avatar
95jersey
I bet you would be better off with a set of gears. I think the A4's come with lame 2:73 rears. You want something like 3:73. This will give you the speed and SOP of about another 50hp vs having to touch your motor, and you won't void your warranty. If you are street driving/drag racing, this is the best bang for the buck.
Old Feb 13, 2006 | 01:48 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Hey Guys ,
Thanks alot .
GM Performance Parts CNC ported heads. Order from GM dealer. I can get them for about $2,100 and they use factory castings so if anybody looks close the casting # stays the same. If you want to go aftermarket you can order heads/cam/headers from SLP. If you do heads only and headers you will gain about 50 H/P, but with cam also you could be closer to 75-85 or more.
Old Feb 13, 2006 | 02:23 PM
1965imp's Avatar
1965imp
forget the heads if you're not gonna put a cam,torque convertor,gears,intake manifold,TB,etc.etc.The complete exhaust system with the "X" pipe will make your car more fun to drive than all the rest of those mods
Old Feb 13, 2006 | 03:20 PM
shurite44's Avatar
shurite44
I am wondering if this fellow posted on the wrong forum by mistake?? He still got some good info though.
To Ported Cylinder Heads
