Help with transmission oil install
Old Aug 9, 2001 | 04:46 PM
carpe dm's Avatar
carpe dm
Default Help with transmission oil cooler install
I would like to install an oil cooler. I have tried all combinations of these words in the search feature and get nada.... Can you point me to a thread that will help me with the installation of an trans oil cooler on my 2000 A4 coupe? I know many "net" Vettes have done this. Thanks!
[Modified by carpe dm, 2:52 PM 8/9/2001]
[Modified by carpe dm, 2:54 PM 8/9/2001]
Old Aug 9, 2001 | 04:57 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Help with transmission oil cooler install (carpe dm)
You mean an external unit (because the stock one's inside the radiator)?
I would have to check my pictures to check which lines to splice. You will need to place it in series but connected to the return line back to tranny.
I think other people here have it also, and may help
Speed-Racer
Old Aug 9, 2001 | 06:25 PM
MDT's Avatar
MDT
carpe dm,
Not a very complicated install, but it can be a little messy. I ran a search and turned up some leads for you to chase.
Try Here
Good luck.
Mark
Old Aug 9, 2001 | 06:36 PM
MDT's Avatar
MDT
BTW, guess I could have mentioned that I ran a Hayden Extra Heavy Duty Part# 679 in my Z-28. The dimensions are 3/4" x 11 3/8" x 11". It's recommended for Class A Motorhomes, towing up to 10,000 lbs. :crazy: :crazy: Have MN6 in the Vette. :cool:
Worked great. My only suggestion: Wear some old clothes that you can peel off and throw in the dumpster.....because it is as I stated above, a messy install....at least for me.
Mark
Old Aug 9, 2001 | 11:06 PM
Speed-Racer
Default Re: Help with transmission oil cooler install (MDT)
Install for the A4 is not at all messy. I lost <1/2 qt
Speed-Racer
Old Aug 9, 2001 | 11:36 PM
MDT's Avatar
MDT
Default Re: Help with transmission oil cooler install (Speed-Racer)
Speed-Racer,
Yeah, I could have done better, I suppose. But with head fimly implanted in ****, I wasn't too careful when determining which line was which.....I swear I didn't run the engine more that 2 seconds with them unhooked. :D :D Honest. :blueangel: But I found out what I needed to know. :lol:
Mark
[Modified by MDT, 9:38 PM 8/9/2001]
Old Aug 10, 2001 | 12:47 PM
carpe dm's Avatar
carpe dm
Thanks you guys; I appreciate the help! :D
Old Aug 10, 2001 | 12:49 PM
carpe dm's Avatar
carpe dm
MDT, your "google" was great! Thanks again
Old Aug 10, 2001 | 12:53 PM
MDT's Avatar
MDT
;) :seeya
Mark
To Help with transmission oil install
