Hot Start Problem
Old Aug 9, 2001 | 06:01 PM
2 Slow's Avatar
2 Slow
Cruise-In III Veteran
Default Hot Start Problem
After doing a cam and pulley install on a 01 coupe, the car experienced some idle problems. The majority of which were solved by drilling a 1/8 inch hole in the throttle body butterfly. Now the car drives and runs just fine but is almost impossible to start when the engine is hot. Cold starts are normal, but the car seems to be a bit rich for about 30 seconds after start up, then it seems to clean up and idle fine. Any thoughts or comments would be appreciated.
Old Aug 9, 2001 | 06:39 PM
MDT's Avatar
MDT
Default Re: Hot Start Problem (2 Slow)
Leaky Injector?
Mark
