I've decided to go with the LS7 clutch and I was wondering, do I reuse the flywheel and just resurface it and do I get a c5 clutch bearing and pilot bearing?
I'm in the process of doing the same thing as you and from what I understand you'll need to use an LS-2 flywheel with the LS7 clutch, then the slave cylinder and pilot bearing are the same C5 pieces.
wow, thanks that anwsered alot of questions only one left. does the flywheel have to be balanced? I heard that some where and was just wondering. oh and can I reuse the throw out bearing or will this become an issue too?
It's good mechanical practice to always replace the bearing with a new clutch
