fault codes...
Old Feb 16, 2006 | 12:22 PM
CorvetteUSCG's Avatar
CorvetteUSCG
Default fault codes...
i have a 2000 C5, my driver side lock recently went out...it will lock but it will not unlock. everything else works. does the same thing when i try to use the switch on the pass side. had the diagnostics, pulled codes. the only ones that sounded unordinary were
IPC- B0516H Speedometer: I have noticed that when I get past 15 mph the mph light goes from dimly lit to brightly lit. But other that that it works fine
A0-LDCM- B2284 Battery #2: ???
Any help would be appreciated, I am a super noobie, I just bought the car 2 weeks ago.
Old Feb 16, 2006 | 12:30 PM
aj98's Avatar
aj98
check for a loose connection on the harness going to the lock/window, etc. You should have about 12 other codes, too - communications errors, lost contact with BCM, and a variety of others.
Possibly a second battery code (B2282 or B2286, I forget which direction the numbers go)
(I get the Speedo error code as well.)
There are a couple of recent threads about this:
Search for gremlins and/or window agony.
I think the bright/dim on the speedo itself is normal - mine has done it since day 1. Depend on (external) light intensity, and likely realted to the light sentinal feature.
AJ
Old Feb 16, 2006 | 12:43 PM
CorvetteUSCG
the harness is inside the door right? i have other codes but they were under differnet categories, most were U1016 H codes that were doubles and a bunch of comms ones, one was current.
it was under the B0-RFA
C2115 H C
could this affect it? that catagory is for the keyless fob isn't it?
thanks in advance for the help
Old Feb 16, 2006 | 12:53 PM
CorvetteUSCG
just cleared the codes. started it up drove around nothing came up. during driving the voltage was at a steady 14-14.5. during the diagnostic mode, voltage was only at 12.5. is this normal? i read on another post that this meant your battery was going bad, which could POSSIBLY explain the door malfunction. But why would everything else work? I haven't checked the grounds but i figure if it was a crappy ground than voltage would be nil.
Should I replace the battery? I haven't changed it since i bought the car.
Old Feb 18, 2006 | 04:43 PM
aj98's Avatar
aj98
The harness is inside the door right? ... just cleared the codes. started it up drove around nothing came up. during driving the voltage was at a steady 14-14.5. during the diagnostic mode, voltage was only at 12.5. is this normal?
Yes, the harness in the door - which is inside the accordion tube.
The 12 or 14 codes I had were all over the place, not just in the "B" area of diagnostics.
When my window/lock/light in the door were not working, voltage ran about 13.3. When I jiggled the accordion tube (and the lock/lights/window) started working again, voltage immediately went back up to 14.2-14.4.
So it seems the loss of door functionality and low voltage are directly related.
But then again, I could be wrong
AJ
To fault codes...
