how do you flush brakes? self bleeder?
1. anyone have the procedure to flush the brakes on a C5?
2. anyone purchase a self bleeder that works by pumping up the container and not with an air compressor? would you byr it again?
" It is very easy to use. Simply add a bottle of brake fluid into your Power Bleeder, screw the Power Bleeder cap onto the master cylinder, pump the handle to the specified pressure with a few pumps, and bleed your brakes. It's REALLY easy. It does not need air from your shop or a spare tire, it's self contained, and you won't have to ask your wife or friend to pump the brake pedal ever again. "
3. which pressure bleeder do you suggest buying?
4. how do people like speed bleeders?
