traction control problem
Old Feb 17, 2006 | 01:58 PM
TigerSharkVette's Avatar
TigerSharkVette
Default traction control problem
i just got my car back, and i put 315's on the back, and no everytime i acclerate especially around 50-60 the traction comes on and basically shuts it down. IT only lets me goe "fast" when I turn it off, could the wider tires cause this, or is there something else wrong
Old Feb 17, 2006 | 04:53 PM
OMG's Avatar
OMG
I have 315's on my car and dont' have that problem, did you get a bigger wheel?
Old Feb 17, 2006 | 05:14 PM
shurite44's Avatar
shurite44
Post you exact tire sizes front and rear.
Old Feb 17, 2006 | 05:43 PM
TigerSharkVette
my tire sizes are 275/30/19 and 315/25/19
Old Feb 17, 2006 | 07:59 PM
vette747's Avatar
vette747
In the standard specs, the diameter of front tires is one inch smaller than the rear. Many guys run the same diameter tire front and rear and have no problem. Looking at the diameter of the size installed in your car, we can see that the rears are smaller than the front. I would say that this is why you have this problem.
275/30 ZR19 25.5 in.
315/25 ZR19 25.1 in.
Old Feb 17, 2006 | 08:11 PM
hightest's Avatar
hightest
You should be running 315/30/19 in the rear. The TC/AH system is really sensitive to having the rears too small in OD.
Don't worry, the 30 series rubber will be much better for traction anyway!
Old Feb 17, 2006 | 08:15 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You have to keep the rear tires taller than the fronts.
Old Feb 17, 2006 | 09:32 PM
turboc5's Avatar
turboc5
My car did that when I had 305/30-18 Fronts and 315/30-18 Rears. Now I run a 285/30-18 in the front and its fine. It was real annoying. I also recalibrated my speedo (hp tuners) with the 315/30-18's since they are slightly shorter than stock. You need taller rear tires or shorter fronts
Old Feb 18, 2006 | 11:43 AM
shurite44's Avatar
shurite44
Old Feb 18, 2006 | 01:08 PM
TigerSharkVette
thanks, im gonna have to do something about it, i couldnt find anything other then 315/25/19's in the back
Old Feb 18, 2006 | 06:20 PM
Paras's Avatar
Paras
Aye... I feel for you... these little problems are annoying (and costly!)
To traction control problem
