I know, its almost sacriligous to even ask this question!
But where I live, leaving a patch can be considered display of speed (read BIGTIME ticket :eek: ) so sometimes I launch with it on.
Just wondering if anyone has played with this and come up with a good launch point for a 6 speed. I've found dropping the clutch at 2k works pretty well. Anyone else?
On the street, all my systems are active but I rarely do hard launches.
At the track I tend to go back and forth between Comp Mode and shutting everything off. In this enviorment, the best place to launch is just above idle. I tried 2500 once and got a terrible 60 foot time...somewhere around 2.5
Hope this helps...
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
reddon, hit button once turns eveything off ( active handling and traction control) after starting car up hit and hold button 5 seconds gets you to comp driving ( has active handling but no traction control)
