Retuning with Hypertech
Old Feb 18, 2006 | 04:48 AM
Pizzano's Avatar
Pizzano
Default Retuning with Hypertech
Does anyone have suggestions as far as resetting the shift points and or firmness on a A4 98 coupe, and Yes only the stock 2:73'S For now, what actually are the factory settings, and what can I safely change them too without adding too much temp rise to the tranny(I understand that Heat is an autos worst enemy), also Fan on /off temps, and any other tips that can be performed on the Hypertech tuner.
Thnx
Old Feb 18, 2006 | 05:03 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I set the shift points like 1 notch lower than the max to be safe for the reasons you state. Forget what I set fan temps for , probably just took a guess.........
Old Feb 18, 2006 | 12:11 PM
Pizzano's Avatar
Pizzano
Is there a noticable difference, and what rpm does the tranny shift at with the new settings.
thnx
Old Feb 18, 2006 | 12:16 PM
BlownV6's Avatar
BlownV6
Fellow C5er used to fool around with hypertech. On back to back pulls he only gained 2 hp so i didn't see the point of paying 400 for it.
As for firmness.. You can set it on the firmest. It's not going to break the tranny.
To Retuning with Hypertech
