Clutch problem??
Old Feb 18, 2006 | 03:33 PM
usnskeet21's Avatar
usnskeet21
Default Clutch problem??
I have been driving my car for a week now about 500 miles after my motor swap. I have an exedy twin disc clutch that has ~5k miles on it. The past couple days i have been having issues with shifting. I can push in the clutch and if i dont rev match the car wont shift, just grind. But if i am sitting still i can go into any gear like normal. I just pulled the inspection cover and all the pp bolts are tight and i dont see any fluid seeping anywere from the slave. The clutch started to engage funny from a stop also like it was not as grabby as usuall. It doesnt slip or anything while driving. Any ideas im lost ! And am suposed to drive 4 hours on monday to go get my car tuned !!!
Old Feb 18, 2006 | 03:48 PM
ecudooberhead's Avatar
ecudooberhead
Do you think perhaps the actual shifter itself isnt in properly? Try to readjust the shifter base by moving it fwd or backward a bit, then retighten- I had a similar problem.
or:
Did you shim your slave cylinder when you installed it? Did you bleed teh clutch? Just a few things to think about
Old Feb 18, 2006 | 04:07 PM
usnskeet21's Avatar
usnskeet21
I didnt touch the slave cylinder. I pulled the motor through the top. I am pretty sure it has nothing to do with the shifter as i havent touched that and it would have nothing to do with the engagement of the clucth. I am just trying to get some feedback as to if i should try to replace the master cylinder or if it seems like its the slave.
To Clutch problem??
