MMS Procharger
Old Feb 19, 2006 | 02:55 PM
iroc90's Avatar
iroc90
Default MMS Procharger
Anyone here using a MMS barcket for there procharger?
Old Feb 19, 2006 | 04:56 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
If you mean Morgan Motorsports, give Chris at East Coast Supercharging a call instead
Old Feb 19, 2006 | 05:00 PM
iroc90's Avatar
iroc90
is morgan motorsprts still in business? cant find any info on them anymore
Old Feb 19, 2006 | 05:31 PM
JoeyG's Avatar
JoeyG
No longer in operation
Old Feb 19, 2006 | 05:33 PM
mdhmi's Avatar
mdhmi
MMS is long gone. The newer revisions of the A&A and ECS ProCharger brackets are much superior.
Mark
Old Feb 19, 2006 | 06:53 PM
iroc90's Avatar
iroc90
hmm ok, well i got a MMS bracket on a good deal that I am going to use, do you guys think it will work well enough on a dialy driver?
Old Feb 19, 2006 | 07:40 PM
mdhmi's Avatar
mdhmi
P1 or D1? 6 rib or 8 rib? How much boost?
Mark
Old Feb 20, 2006 | 01:08 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I wouldnt install an MMS bracket in my car if you paid me to do it...
VR
Old Feb 20, 2006 | 02:29 AM
iroc90's Avatar
iroc90
6 rib, going to try and run 6-8psi, P1SC, why would you not run this bracket is it that bad??
Old Feb 20, 2006 | 02:33 AM
mdhmi's Avatar
mdhmi
6 lbs on any bracket shouldn't be a problem. You can always switch over to the ECS, A&A, or ProCharger Stage II bracket setup down the road if needed.
Mark
Old Feb 20, 2006 | 02:41 AM
iroc90's Avatar
iroc90
yeah thats what i figured, i just wanted to have a little more kck to it, already have a 1990 Iroc powered by a Vortech that runs pretty good, it also had one of the first prochager that were out for that car at the time and it also had belt issues but i was able to shim it and get it to run before i switched over to the race version vortech, i think the MMS would work finem but will have to wait and see what issues I have
Andy
Old Feb 20, 2006 | 02:21 PM
BlackMagicC5's Avatar
BlackMagicC5
I used that bracket on my procharger setup. I switched to a&a and would never go back. MMS bracket sucks. Put it on ebay or something. I wouldn't even consider it for a daily driver, unless you plan on never taking it into boost. It's not reliable.
Old Feb 20, 2006 | 02:34 PM
iroc90's Avatar
iroc90
man this sucks, well i only paid 100$ for it, so i figured it was worth the try, but if its that bad i will have to switch over to the A&A.
Old Feb 20, 2006 | 03:35 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Go with the A&A setup I know I have Jons old one and it works fantastic for me an my little ole 346 setup
Old Feb 20, 2006 | 05:37 PM
mdhmi's Avatar
mdhmi
For $100 I wouldn't feel bad about chucking it into the trash.
Do yourself a big favor and start with an A&A or ECS 8 rib.
Mark
Old Feb 20, 2006 | 05:42 PM
iroc90's Avatar
iroc90
ok ok enough already, you guys convinced me that its not worth using, I will get the A&A Bracket
thanks
andy
Old Feb 20, 2006 | 11:24 PM
BlackMagicC5
Mark
He's going to spend all that time installing it, messing with those idlers, getting the proper belt size, ect, only to switch out after a few hundred miles. Hell, I spent a lot more than 100 bucks on mine. I'm sure someone with the regular ATI kit might want it. I think its an upgrade for them, if you can call it that.
To MMS Procharger
