Proper C5 6sp 1/4 mile launch
Old Feb 19, 2006 | 04:47 PM
stnick's Avatar
stnick
Default Proper C5 6sp 1/4 mile launch
In the process of getting 5 average 1/4 mile runs prior to my Vararam install, I smoked my clutch disc. It's working okay now, however, I was feathering the pedal through 1st gear and when I shifted to second the pedal had about twice the play in it as I shifted and I noticed smoke from the clutch coming out the rear of the car and smelled the disc.
Do you guys simple dump the clutch and controll wheel spin with throttle or what?
Old Feb 19, 2006 | 06:25 PM
fotoboy's Avatar
fotoboy
supercar f1 tires I launch as high as 4200rpm at the track on the street its 2500 ish a fast let out of the clutch (slight feather works best) I pulled 1.83 60ft with 356 rwhp
on drag radials I can leave at 5200 or above but your cluch will not last long ( I have a powergrip) my 60ft didnot get any better with the BFG and 17x11 zr1 rims due to 3lb heaver per wheel and went .04 slower
I figur I did not have enough hp to overcome the new rubber to make them work, this year it wont be a problem with 200 more rwhp
Old Feb 19, 2006 | 06:43 PM
gsxzo6's Avatar
gsxzo6
refer to rangers guide to drag racing...use the search button....user name is RANGER...i followed his guide and launched at 3300-3500 on f1's with low pressures and clicked off a ton of 1.8's some 1.7's and even a 1.67 on stock everything(2002 z06) follow his write up it is very good..
Old Feb 20, 2006 | 03:23 PM
fotoboy's Avatar
fotoboy
Thats great 60 ft! I think there is a difference in tech between a c5 and a zo6 being 100lb lighter and a m12 over a m6 being the m12 has deaper first 3 gears
Old Feb 20, 2006 | 06:22 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Maybe so but you can still learn a lot from Ranger's post.
Old Feb 21, 2006 | 11:45 AM
fotoboy's Avatar
fotoboy
agree, can you post a link to rangers post? Thanks
Old Feb 21, 2006 | 01:23 PM
Nithros's Avatar
Nithros
St. Jude Donor '09
Ranger from a dig.
Old Feb 21, 2006 | 02:56 PM
fotoboy's Avatar
fotoboy
Thanks, I believe that I read that before,but always good to read multiple times.
Old Feb 21, 2006 | 04:46 PM
FKING1's Avatar
FKING1
With a highly modified 2000 M6, I dump the clutch at 2500 rpm then feather it until it hooks up. Gets me in the 12's.
Fred
Old Feb 21, 2006 | 11:14 PM
jjcslynn's Avatar
jjcslynn
Will a stock rear hold up to dumping the clutch or even spinning the tired? I blew my rear spinnoing the tires on a wet road when I first got the vette. Now I'm leary of breaking the rear loose. How much abuse will stock output shaft take before breaking?
Old Feb 22, 2006 | 02:00 PM
fotoboy's Avatar
fotoboy
knock on wood, I have been driving my car "spirited" ( dont think I have ever not gotten on it taking it out) for 3.5 years and never had a problem. This includes 5200 rpm launches on DR ant the track.
Old Feb 22, 2006 | 03:17 PM
mean lx's Avatar
mean lx
What kind of sixty foot times are you seeing with 5200 RPM launches and have you broken any drivetrain parts? What mods have been done to your C-5? James
To Proper C5 6sp 1/4 mile launch
