need quick answer please: rear sway bar torque specs.
Old Feb 22, 2006 | 07:15 PM
GlassMan99's Avatar
GlassMan99
Default rear sway bar torque specs?
I'm in the middle of removing and reinstalling the bushings on the rear sway bar on a 99 coupe. I'm doing this to eliminate a creaking sound. Once I lubricate and reinstall the bushing what are the torque settings Thanks.
Old Feb 22, 2006 | 07:25 PM
wrustywrench's Avatar
wrustywrench
ehh,,,,,,you gotta remove the clamp to get the bushing in....dont ya???
Old Feb 22, 2006 | 07:29 PM
GlassMan99's Avatar
GlassMan99
Thanks.
Old Feb 22, 2006 | 07:49 PM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Rear stablizer bar lower clamp nut 70 ft/lb, upper clamp bolt 49ft/lb.
To need quick answer please: rear sway bar torque specs.
