I am looking for feed back regarding the use of a Kenne Bell pump on a N/A motor. I am on the ragged edge as far as the stock fuel pump goes. (most say over the edge) I was thinking of going with the racetronics system but feel the Boost a Pump would provide plenty of fuel if it increases it the way it is advertized.
Less money and an easier install...
Anyone using this pump on a N/A sysytem? Any feedback will be appreciated.
activates ONLY at full throttle (naturally aspirated) or at 3 psi (turbo or supercharged). And it acts as a voltage regulator by compensating for any and all system voltage fluctuations.
So yes it will work and it will help, but the best solution would be the racetronix fuel pump and wire harness. About the same cost and very easy to install....
