slow trans leak
Old Feb 23, 2006 | 06:22 PM
STEEL's Avatar
STEEL
Default slow trans leak
My trans has a slow leak where it has the largest circumference where it splits in half. It is not leaking but has dirty oil like grime right by the seam, I went to GM and they said it wasn’t a gasket but they seal it with some red sealer. The tranny is coming out for a clutch change and was wondering how hard is it to split the trans and clean it to reseal it.
Old Feb 23, 2006 | 08:10 PM
HERK's Avatar
HERK
mine is doing the same thing,its a 2000
Old Feb 23, 2006 | 10:15 PM
HERK's Avatar
HERK
ttt
Old Feb 23, 2006 | 10:25 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Are you sure it's the tranny of is it the trans-axel housing. This is a common problem and most here that have had the affliction have had it done under warranty. They replace the seal which is a large O-ring and also the half shaft seal. There is a replacement seal for the differential housing. My .02
Old Feb 24, 2006 | 01:37 PM
STEEL's Avatar
STEEL
im pretty sure its the trans
Old Feb 24, 2006 | 03:42 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I just had my seals replaced on my 2000 and when I get the new Torq Converter installed I am having my tranny filter and gasket done too.
Micah
Old Feb 24, 2006 | 06:50 PM
VetteTech81's Avatar
VetteTech81
Was this a 6speed or auto.. there are a couple issues I have seen with leaks..
6speed the gear selector shaft seal & case halfs leaking (which are assembled with silicone RTV ect from the factory)
Auto.. I've seen the out put shaft seals leaking there is a revised seal from GM, seen pan gaskets, torq converter hub seal, and other leaks..
Assuming it's a 6 speed to split the case to re seal shouldn't be all that hard with the trans out of the car..
-=Rick
Old Feb 25, 2006 | 01:12 AM
STEEL's Avatar
STEEL
It is a 6 speed, and where could I find this sealer?
To slow trans leak
