Coolant Flush Procedure...Why the Difference??
Old Feb 25, 2006 | 02:18 AM
LIGHTNING's Avatar
LIGHTNING
Default Coolant Flush Procedure...Why the Difference??
Noticed the procedure for performing a coolant flush is different in the 2000 C5 GM Shop Manual vs. the 2004 Manual. The '00 says you should use clean drinkable water.... '04 says deionized water. '00 says after filling system, run engine with pressure cap off for 30 seconds....'04 says run engine with cap on. '00 says to rev engine at from 2-3k rpm's, up & down for a few minutes....'04 says run the engine for 20 minutes. Why the differences??
Old Feb 25, 2006 | 04:43 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
got me...first I have heard this....
the only write up I have ever read is this one
http://forums.corvetteforum.com/show...post1550969620
may wanna PM Patches and see if he knows why...
Old Feb 25, 2006 | 03:54 PM
FKING1's Avatar
FKING1
Took my 00 to the Dealer who uses a chemical flush. I gave them distilled water to add to the anti freeze. Cost $100.
Fred
Old Feb 25, 2006 | 07:33 PM
LoneStarFRC's Avatar
LoneStarFRC
Fred
I like distilled water also. No minerals and cheap too.
Old Feb 25, 2006 | 08:24 PM
LIGHTNING's Avatar
LIGHTNING
What's the difference between distilled & deionized water?? Noticed the GM Service Manual says to use deionized water.
Old Feb 25, 2006 | 10:17 PM
soggysailor's Avatar
soggysailor
Is there an issue with the coolant type. I've had a few pros tell me to not use the red dexcool . They say it wants to gel or crust up in the system.
Old Feb 25, 2006 | 10:41 PM
W Muller's Avatar
W Muller
Distilled water is distilled. Deionized water is run through an ion exchange deminerlizer. The end result is about the same. The dissolved solids and hardness are removed from the water, leaving it fairly pure.
Old Feb 26, 2006 | 04:33 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Who sells distilled water? Can you buy this at auto supply stores or a specialty shop?
Bob
Old Feb 26, 2006 | 04:43 PM
Pizzano's Avatar
Pizzano
Bob
Any Grocery store in the bottled water isle.
Old Feb 26, 2006 | 05:24 PM
BobbyG's Avatar
BobbyG
Cool
Bob
To Coolant Flush Procedure...Why the Difference??
