Ripper Install Question?? Stops or Not?
Old Aug 11, 2001 | 06:59 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Ripper Install Question?? Stops or Not?
Just got my Ripper today... was reading the B & M instruction sheet and had a question about the shift stop adjusters..... I think I read somewhere in the forum that it is better NOT to install the stops??? What's the real scoop? :chevy
Old Aug 11, 2001 | 08:17 PM
maninblack's Avatar
maninblack
Default Re: Ripper Install Question?? Stops or Not? (XmentalPilot)
just to warn you ,the ripper is very very stiff and it takes a long time to get use to. and you dont need to use the alignment screws :chevy
Old Aug 11, 2001 | 08:31 PM
ledfoot's Avatar
ledfoot
I've got the Rippper.
I didn't do any adjustments. I just put it in and drove. It is STIFF. I hope you like racing, becuase if you don't, you may not like the shifter. It is the drag strip where the ripper shines. I haven't missed third since I got it.
Good Luck
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
Old Aug 11, 2001 | 10:27 PM
allanlaw's Avatar
allanlaw
There are no stop adjustments on the Ripper model that ships currently. There was an older model that did have adjustments, and they may still be on the generic Ripper model. But there are no stop adjustments on the current C5 Ripper.
Old Aug 12, 2001 | 12:34 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Ripper Install Question?? Stops or Not? (allanlaw)
received and installed my ripper in December and it had no shift stops.
Old Aug 12, 2001 | 12:37 AM
XmentalPilot
RIght.. I noticed just the stops were not anywhere with the kit...wonder why the instructions still make the reference?? ANother problem solved!
Thanks ! :chevy
btw: PK i want a couple of those hood ornaments for my car!
[Modified by XmentalPilot, 8:39 PM 8/11/2001]
Old Aug 12, 2001 | 10:40 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In V Veteran
The newer Rippers do not have any stops .. good luck :seeya
Old Aug 12, 2001 | 06:13 PM
XmentalPilot
Default Re: Ripper Install Question?? Stops or Not? (CHRIS NJ C5)
Installed!!! BIG difference, I like everything about it! The feel is very
positive +++++ :yesnod:
Old Aug 13, 2001 | 10:19 AM
Chuck Broten's Avatar
Chuck Broten
As has been said before, no stops on the model shipping now. I was also confused by the instructions.
One adjustment you might want to check involves the key that is on the stock shifter. With the Ripper installed, bolts not tight, and in neutral, slip the key into the hole at the front of the shifter. You might have to move the shifter forward or backward to get the key into the hole. On mine I didn't have to move it at all. Now tighten the bolts. This centers the shifter. Remove the key and store it someplace where you can find it if ever needed again. The stock shifter had a place for storage.
The shifter will be stiff but loosens up over time. Change the shift know and it will get even shorter. Very good mod, you won't be disappointed.
Hope this helps.
Old Aug 13, 2001 | 10:29 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
No stops
To Ripper Install Question?? Stops or Not?
