Engine Missing & Low Idle Problems after Tunnel Plate Install
Old Feb 26, 2006 | 10:26 PM
Speed Trap's Avatar
Speed Trap
Originally Posted by gpotski
It doesn't seem to be related to the tunnel plate install, or the shocks.
Sounds more like a coincidental engine problem.
Here's a thread link which might offer food for thought...
http://forums.corvetteforum.com/show...956&forum_id=1
I didn't get a chance to check it out today at all but I think your right about it being unrelated. Now I just have to figure out what it really is now that I've realized that I looked in the wrong section on the Predator when I found the 12 non existent trouble codes. (note to self, don't play with new toys without reading instructions).
Thanks.
Old Feb 27, 2006 | 04:11 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Thanks.
instructions??? we don't need no stinkin instructions
I must admit as I get older I tend to actually at least glance at the instructions first
Old Mar 11, 2006 | 03:20 PM
Speed Trap's Avatar
Speed Trap
Default UPDATE: Problem Solved
Just wanted to update all of you who provided suggestions. I think I have finally gotten the problem taken care of. It had nothing to do with the tunnel plate install or the O2 Sensor, just coincidence (and I thought there was no such thing) that it showed up after the install. Once I figured out that I was reading the Predator incorrectly and that I had no current codes, I put in a new battery (it was needed anyway), but this had no effect on the problem. I also checked the grounds, all look good. I then checked the plug wires (all good, 330-370 ohms readings) and changed the plugs (that was fun - not). This made things a little better but still not right. I then removed the remaining fuel from the tanks and changed the fuel filter. Once that was done the problem was gone. I guess it was the fuel or filter or maybe a combination of both plus the plugs. Which ever it was, its now running good again.
Thanks to all of you who helped out.
Old Mar 11, 2006 | 04:50 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Glad to hear its running right now!!
VR
Old Mar 11, 2006 | 05:18 PM
LoneStarFRC's Avatar
LoneStarFRC
I was about to suggest a fuel pressure check here, but seems like you got things covered.
I'm thinking your filter/regulator may have been the problem. It's possible, I guess, that your fuel pressure was low but not low enough to trigger a P0300 (misfire code) also and thereby get a CEL too.
Old Mar 11, 2006 | 07:41 PM
Speed Trap's Avatar
Speed Trap
I actually did get the flashing check engine light on one occassion with the P0300 code. However, when I checked it again shortly afterwards the code was gone, not even a history code for it. I didn't reset it to clear it so I don't know what happened to it. Just glad its all better now.
