Rocker Panel Replacement
Old Feb 26, 2006 | 11:29 PM
NEVERL8C5's Avatar
NEVERL8C5
Default Rocker Panel Replacement
Has anyone replaced their rocker panels? Is it a bolt on or do you have bonding also? I have a break at the fender screw attach point on the drivers side, I have not taken anything apart but the fender is loose at that point.
Old Feb 27, 2006 | 12:14 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Rockers are glued on...
Old Feb 27, 2006 | 12:17 AM
Cscokd's Avatar
Cscokd
This seems to be a pretty common occurance. Mine did the same thing. The rocker panels are bonded to the frame and are very difficult to replace. I made a couple of small metal plates to slip up under the fiberglass panels and screwed them together. Then I immediately purchased A&A's rocker rail protectors.....money well spent.
John
Old Feb 27, 2006 | 12:56 AM
NEVERL8C5's Avatar
NEVERL8C5
Thanks I will attempt to repair, Has anyone seen the repair pieces eclers sells? I wonder if this is the piece for that area .I was at their store on Xat. but could not determine if it is for this area and the counter person was not sure .
To Rocker Panel Replacement
