MT ET Street Radials in 275.40.17 what psi should i run @ the track ?
Start at at 20psi hot and go down if needed..........
As a soft tire, it gains PSI after repeated runs.
Friday I was cutting 1.49-1.50 60' with 24 psi hot
Never got a chance to go lower
These tires are STICKY!
I started at 20 and worked down to 18 and cut my best of 1.59 60'
I dropped to 16 and bogged too much for my set up. I was launching at ~5200rpm with a quick release of the clutch. I was very surprised at how well these grabbed the track.
Scott
