Tranny Shifting/Slipping
Old Feb 27, 2006 | 03:58 PM
GeorgieMporgie's Avatar
GeorgieMporgie
Default Tranny Shifting/Slipping
A good friend of mine has 2000 coupe with an automatic trans and he notices it slips from second to third and third to fourth occassionally. Usually does it after the fluid get up to temp, but the problem is not consistently occurring. He took it to the stealership and they hooked it up to the computer and it didn't show anything. They then test drove for a while and it didn't slip? Any suggestions?
Old Feb 27, 2006 | 04:13 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
The only thing I can tell you, is that it sounds like it's life is about over.
He needs to check the fluid to make sure that it is full and to see if the fluid is burnt. (Dark brown or black)
Depending on the miles it wouldn't hurt to service it new filter and fluid.
Old Feb 27, 2006 | 06:14 PM
Gitusum's Avatar
Gitusum
Old Feb 27, 2006 | 07:27 PM
99bronzecoupe's Avatar
99bronzecoupe
I just had mine rebuilt. Your symptoms are the early stages of its slow death. I had same symptoms, they got progressively worse.
Old Feb 28, 2006 | 05:38 AM
SFengineer's Avatar
SFengineer
Don't know if i can agree with this, i did it and it killed my tranny. i was told that the clutch materials floating around in the fluid actually allow it to grab better. With new fluid i slipped even worse.
Old Feb 28, 2006 | 06:31 AM
Shane_S's Avatar
Shane_S
Sounds like it's almost time for a 6-spd conversion.
Shane
Old Feb 28, 2006 | 07:26 AM
dpd's Avatar
dpd
,your buddies trans is in death mode
Old Feb 28, 2006 | 04:36 PM
torchvette10's Avatar
torchvette10
Yep, the tranny is dead!!
But tell him not to be sad because once he get a tranny from Rodney RPM transmissions he will be happy that the stock one died! He should get one with a higher stall. I have the RPM level 5 tranny with a 2800 TC and I'm beating the crap out of it all the time with around 450 RWHP, and it holds really really well!!
www.rpmtransmissions.com
Old Feb 28, 2006 | 06:16 PM
GeorgieMporgie
Could be worse. It could be me.
Just kidding, I'll break the news gently. Thanks for the info All.
Old Feb 28, 2006 | 06:36 PM
Dave00C5's Avatar
Dave00C5
Put a fork in it, its about done.
To Tranny Shifting/Slipping
