Is my blackwing throwing codes?
Old Feb 27, 2006 | 05:00 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Default Is my blackwing throwing codes?
My check engine light came on and is throwing the codes a1-rdcm and ao-ldcm. The last time the check engine light came on I took it to the dealer and they said it was the blackwing causing it. Think there is any truth in this?
Ron
Old Feb 27, 2006 | 05:04 PM
chaase's Avatar
chaase
St. Jude Donor '12
Ron
If the codes are from RDCM and LDCM, which I believe to be Right/Left Door Control Module...The blackwing has 0, effect on the door control modules.
Chris
Old Feb 27, 2006 | 05:18 PM
50th year's Avatar
50th year
Thanks.
My window won't go up or down. Strange to see a check light for a window. I can hear clicking when I push the button. It didn't work a few days ago then it started working again. Guess Iam off to the dealer.
Ron
Old Feb 27, 2006 | 07:16 PM
dpd's Avatar
dpd
Ron
if your check engine lamp is on,you most likely have a "lean running" fault for it to be the blackwing.check the fault.as far as the door control
modules,i highly doubt it.
To Is my blackwing throwing codes?
