Changing Front Spring, Need some help!
Old Aug 12, 2001 | 02:04 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Changing Front Spring, Need some help!
Ok, I just bought the poly eurathane kit, tie rod ends, and 850 lb front spring. I need to know how to get the front spring out. After I got it up on jacks and got underneath the car it looks a lot different to the rear spring. Does it just sit ontop of the control arm, it has to attach somewhere. Any suggestions before I get started would be appreciated. :confused: :(
Old Aug 12, 2001 | 10:18 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Changing Front Spring, Need some help! (Shinobi's97)
Support the vehicle on stands,disconnect the sway bar links,front shocks at lower end,and split the lower ball joint.Swing the lower control arms down and out it comes.
When reinstalling,place a floor jack under the left and right ball joints to raise the control arms EVENLY.This will prevent the spring from shifting from side to side...
