I need torque settings/ jack placement
Old Aug 12, 2001 | 10:18 AM
ledfoot's Avatar
ledfoot
Default I need torque settings/ jack placement
Hello-
Taking off the wheels for the first time to clean the wells. I've done the driver's side front already but I've just tighten the lug nuts enough to lower the jack. Can someone give me the settings please? I have a craftsman wrench if this makes a difference.
Also, where are you guys placing your jacks when you lift?
I've got a dk20. I came from the side when I did the driver's side front tire. I'm so paranoid that I used a hockey puck WITH a cloth towel over it and I still felt uncomfortable. It didn't feel right. I know the dk20 will slide under from the back but will it slide under from the front??
Thanks in advance
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
[Modified by ledfoot, 8:20 AM 8/12/2001]
Old Aug 12, 2001 | 10:26 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: I need torque settings/ jack placement (ledfoot)
I believe the lugs are 30-60-100 ft-lbs in a cross-tightening pattern. I also try and get as much done as possible while it's in the air and do the final tightening when back on the ground. I personally tighten to a final of 95.
As for the jack, I center under the forward and rear cross-members using a pice of wood to span the entire rib....hope this helps
Mark
[Modified by Mean Green 2000, 9:27 AM 8/12/2001]
Old Aug 12, 2001 | 10:40 AM
Ranger's Avatar
Ranger
....Can someone give me the settings please?
Torque spec for the lug nuts is 100 ft-lbs. Suggest doing it in a three stage process of 50, 75, 100 in a star pattern.
Regarding the jack points, I've emailed you a diagram that Chem Zabrowski previously sent me.
Hope it helps,
Ranger
Old Aug 12, 2001 | 10:42 AM
ledfoot's Avatar
ledfoot
Default Re: I need torque settings/ jack placement (Mean Green 2000)
Thanks Mark!
Old Aug 12, 2001 | 10:44 AM
ledfoot's Avatar
ledfoot
Default Re: I need torque settings/ jack placement (Ranger)
Thanks Ranger!
I love the forum.
To I need torque settings/ jack placement
