Torque converter upgrade
Old Mar 1, 2006 | 08:04 AM
mperl93's Avatar
mperl93
Default Torque converter upgrade
I see many people talking about changing to a higher stall torque converter and its drivability. I am not at all knowledgable on this subject and would like some clarification. I have an 04 A4 2.73 and would like to upgrade to 3.42 gears. What I don't know is if I would like to change the converter to a higher stall. What feel does a car with a higher stall t/c give you? Is the car jumpy off the line? Does it shift real hard? Does is rev higher before rolling? I drive in traffic pretty often and don't want a car that will jump every time I tap the gas to move up in traffic. But I do want better acceleration. If possible help me understand what the higher stall does so that I can determine if I want to leave mine stock or upgrade to a high stall with the 3.42 gears.
thanks,
Mike
Old Mar 1, 2006 | 08:18 AM
torchvette10's Avatar
torchvette10
I have a 3.15 differential with a 2800 TC. What I noticed when I insalled the new TC was that the gas pedal feels loose, more than it used to, you RPMS icrease quickly and the car revs higher during acceleration.
Basically, a TC puts in in your power range quickly. Your car accelerates faster. For instance when you get on it through second and wait for the tranny to shift into third, you'll notice that the RPM do not drop as much as they used to with the stock TC. It keeps the car in a good power range!
Old Mar 1, 2006 | 08:19 AM
willyfastz's Avatar
willyfastz
I would deff reccomend a higher stall with your A4. You wont get any jumping or anything like that from a start. It will rev a little higher to get going. As long as you don't get an incredibly loose converter it wont be a whole lot defferant than stock. Get something in the 3000-3500 rang and you'll love it.
Old Mar 1, 2006 | 09:29 AM
1965imp's Avatar
1965imp
You will not notice a difference in drivability with a 3200 stall and 3.42 gears. As long as you've got the rear end out of your car you MUST go with a higher stall torque convertor.! I have had guys tell me to stay with my 2.73's and just go with a higher stall. Also,if you go with a new torque covertor put a good trans cooler on while you're at it.
Old Mar 1, 2006 | 10:33 AM
99 vett babycar's Avatar
99 vett babycar
as long as you're not planning additional mods, like H/C, you should be happy with something in the 2800 to 3000 range. If you're going to do H/C at some future date you'd be better off with something in the 3200 to 3800 range because that size TC will better complement the additional torque you'll get out of a H/C package.
Don't worry about the "looseness" you'll get used to it in a day or two and after a week you wont even remember what stock felt like.
Old Mar 1, 2006 | 10:42 AM
Dave00C5's Avatar
Dave00C5
with all the posts. You'll not feel any real downsides however with 3.42's and 2800 to 3200 stall convertor you'll pick up around 7 tenths in the quarter mile acceleration. You'll be drivin a whole different car and when the convertor locks up it will feel just like stock except for around 250 rpm's more on your tach per given mph. Hope this helps.
Old Mar 1, 2006 | 11:02 AM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
dave said it all
Old Mar 1, 2006 | 02:07 PM
BLOWN'NC's Avatar
BLOWN'NC
3.73s with 2800 Vigilante here and it's a rocket with no loss of rpms or boost with shift changes (thanks RPM)
On the other hand, I have a buddy with an LPE 427 TT A4 with 2.73s and a 3600 stall------the stall makes up for the tall gears, but he can still go 220mph if the urge hits him!
Old Mar 1, 2006 | 02:32 PM
Dave00C5's Avatar
Dave00C5
Old Mar 1, 2006 | 03:36 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
And Get a transmission cooler!! Cheap insurance.
Old Mar 1, 2006 | 04:08 PM
tiojames's Avatar
tiojames
Default convertor
I changed from 3:15s to 3:42s and a yank 3500. Within 30 miles of the install I was in bumper to bumper traffic for 2 1/2 hrs, I did not notice any appreciable differance in drivability. The cost to install a convertor is usually $100 or less when you have the diff out. I recommend you do it. My .02
Old Mar 1, 2006 | 05:14 PM
black98c5's Avatar
black98c5
I have the 2:73 gears. I'm having a shop put in a yank ss 3200 stall. is it true i can knock off more than a second in the 1/4?
Old Mar 2, 2006 | 05:41 PM
Ponchorello's Avatar
Ponchorello
What tranny cooler would you guys recommend?
Old Mar 2, 2006 | 05:44 PM
BlownV6's Avatar
BlownV6
My ET dropped from 13.3 to 12.5 with just the addition of a 3000 stall and DR's with my stock 2.73 gears.
Old Mar 2, 2006 | 06:31 PM
Ponchorello
What other mods did you have at the time?
Old Mar 2, 2006 | 06:43 PM
black98c5's Avatar
black98c5
I cant wait to get mine installed.
Old Mar 2, 2006 | 07:08 PM
BlownV6's Avatar
BlownV6
None. The runs were at one of if not the fastest track on the east coast. Any other track would probably see .5 reduction with just stall and DR's.
To Torque converter upgrade
