tire revs. per mile ?
Old Mar 1, 2006 | 01:47 PM
dale528's Avatar
dale528
Default tire revs. per mile ?
currently have stock set-up for 04 coupe changing to Z06 wheels and need to buy tires. Question is odometer change for more revs. verses less revs.
Old Mar 1, 2006 | 01:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Neither, our cars have a VSS, Vehicle speed sensor. Tire height will not change the speedo
Old Mar 1, 2006 | 02:19 PM
SMR 67's Avatar
SMR 67
Do all C5's have these vehicle speed sensors including the Z06? Are you saying that the sensors automatically detect any wheel or tire size changes and adjust the speedometer accordingly without any reprogramming of the computer or swap-out of a rear speedo gear like in the older cars?
Old Mar 1, 2006 | 02:42 PM
screw991le's Avatar
screw991le
From what I understand all C5s have VSSs
Old Mar 1, 2006 | 06:37 PM
turboc5's Avatar
turboc5
Yes they do have vehicle speed sensors but the speed and miles are calculated by the computer based on info by the speed sensors and compared to a stock tire height. If you go to a shorter tire the computer won't know the diffrence and your mph will read faster than you really are going. When I put on my 315/30-18's they were shorter than stock and my spedo was off. I reprogramed the tire height withh my hp tuners. Now it is ded nuts on. If you go with zo6 wheels just use the stock tire size for a zo6, the overall heights will be the same.
Old Mar 1, 2006 | 09:24 PM
screw991le's Avatar
screw991le
Someone else chime in?
TTT
Only changing the gears would throw off the speedo.
Old Mar 1, 2006 | 09:34 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
TTT
Changng gears does NOT throw off the speedometer (because the reading is based off wheel speed, not tranny shaft speed) .
Tire height most certainly does affect the read wheel speed, and the speedometer.
Going to a shorter tire will make the speedo read faster than what you're actually going. Most of the prgramming tools out there can plug in a new rear tire height to adjust for that....but the error will be very slight, ie: 1-2mph at freeway speeds, and most people don't bother with it.
Old Mar 1, 2006 | 10:52 PM
dale528's Avatar
dale528
very helpful as usual. I think I'll get the tires I want and not worry about the small stuff
Old Mar 2, 2006 | 10:41 AM
SMR 67's Avatar
SMR 67
Thanks for the replies on this.
Old Mar 2, 2006 | 04:46 PM
Dirty Howie's Avatar
Dirty Howie
Will this also throw off the MPG ??????
I just changed wheel/tires and my milage is lower
DH
Old Mar 2, 2006 | 04:48 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
TTT
In effect changing tire is the same thing as changing gears when it relates to speedometer readings. A taller tire is like changing from 4.10 to 3.73 and a shorter tire is like going from 3.73 to 4.10. The tire size changes the revs per mile and WILL throw the speedo off.
Old Mar 2, 2006 | 04:50 PM
RichieRichZ06
St. Jude Donor '08
Most tire company websites will show the overall size and revs per mile for their tire sizes. It is a good place to figure how much percentage wise it will be off.
Old Mar 3, 2006 | 12:03 AM
Dirty Howie
So it would also affect gas milage..........
DH
Old Mar 3, 2006 | 10:03 AM
Bill.Jarboe's Avatar
Bill.Jarboe
After reading this post I had to throw my 2 cents in... an engineer can't walk away from a math question
Tire height(diameter) * pi (3.14157), will give you the circumference of the tire. A factory tire is ~26" tall with a circumference of ~81", smaller tires would still be ~25" tall with a circumference of ~78.5 inches. sooo... (81/78.5)*60 = 61.9. the speedo(and everything else) would be off slightly less than 2mph(3%) at 60 mph.
I have seen cars come out of the box brand new that were off farther than that. I wouldn't bother unless I had both the time and the equipment in front of me.
To figure what the difference will be for any one particular tire change:
A: Measure the current tires from the ground to the top of the tire, multiply it times 3.14157(pi)
B: Measure the tires you are considering from the ground to the top of the tire, multiply it times 3.14157(still pi )
divide A and B and subtract 1, the answer is percentage that the speedometer readout will change. Multiply this by the speedometer reading at the moment and it will give you actual speed. It will also show that it would take a pretty drastic change to have a big effect.
According to the diagrams, the speed sensor is located on the rear of the transmission, while I could be wrong, that implies that it's attached to an output shaft rather than an input shaft, if this is true a gear change would not affect readings, however a tire change would.
And now, back you your regularly scheduled show.
Old Mar 3, 2006 | 10:32 AM
RichieRichZ06
St. Jude Donor '08
DH
Yes a little bit.
To tire revs. per mile ?
