2000 c5 LS1 block hp limit????
Old Mar 2, 2006 | 12:36 AM
corvetteracer22's Avatar
corvetteracer22
Default 2000 c5 LS1 block hp limit????
Does anyone know the hp limit on a 2000 c5 ls1 block??
Old Mar 2, 2006 | 12:42 AM
mdhmi's Avatar
mdhmi
Over 1,000 if it's built properly.
Mark
Old Mar 2, 2006 | 08:23 AM
torchvette10's Avatar
torchvette10
That's a lot when you think about it!
Old Mar 2, 2006 | 08:48 AM
MissZ06's Avatar
MissZ06
Block and crank are plenty tough, its rods that get weak.
Old Mar 2, 2006 | 09:05 AM
torchvette10
Yep, and pistons under high boost!
Old Mar 2, 2006 | 09:27 AM
DoubleZ06's Avatar
DoubleZ06
The block and crankshaft will easily withstand 800-1000hp.
Old Mar 2, 2006 | 03:01 PM
BickyDhadwal's Avatar
BickyDhadwal
not highjacking but how about stock internals and stuff? ive heard those are only good to about 500??
Old Mar 2, 2006 | 03:45 PM
torchvette10
Yep! You're right. With Stock pistons and rods, you don't wanna go over 500-550 RWHP, which is about 7-8 PSI for supercharged cars
Old Mar 2, 2006 | 04:30 PM
chaase's Avatar
chaase
St. Jude Donor '12
600HP (at the crank) is about the limit for the rest of the internals
Old Mar 2, 2006 | 05:23 PM
BlownV6's Avatar
BlownV6
I had thought of just using my stock block with new internals but i'm building 6L with the Iron block LQ9
To 2000 c5 LS1 block hp limit????
