air sencor issues
When removing 1st generation sensors and reusing them, you need a new "O"ring washer. Your 99 sensors would have been fine, they require that the nut be torqued to 106 in pounds. 9 ft lbs.
You can not do anything to stop the warning on the DIC.
Your 99 sensors are eight years old. I suggest you buy 2 new sensors from gene Culley at Fred beans and two washers and two nuts,.
If you still have your old sensors, take a look at the date stamp on the sensor... IT is a molded in circle that looks alittle like a clock, it will indicate the month and year of manufacture.
gculley@fredbeans.com
you need to install them, then do a full sequence tire sensor relearn.
Good Luck
Bill aka ET
