is there a speed limiter on the 2002 zo6 corvette.? i can only top out at 153mph . why? please help. i already used the diablo programmer on the car and the car has all the bolt on's in place.
What Gear are you trying this in....I believe you need to be in 5th not 6th gear to achieve top speed......
Pat
i was afraid to push the rpm's to high. i thought the 6th gear was where you got the top end speed. i was approaching nearly 6000rpm and only hit 153mph kinda scary and confusing
Man 6000rpm in 6th gear? Either you have a nasty rearend or your clutch is in need of repair. Wow I don't think I have ever heard of 6000 rpm in 6th gear something is weird. It will be interesting to see what the other's have to say.
I would repost this in another section to get more replies
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
According to my calculations if you were in 6th gear @6000 rpm's in a Z06 your speed should be 235 mph, in 5th you would be going 156. Are you sure you were in 6th gear? The HP required to go 6000 rpm's in 6th would be tremendous.
