LG Street series
Old Mar 3, 2006 | 11:20 AM
NEWZ06's Avatar
NEWZ06
Default LG Street series
Just ordered a set of the street series headers from LG. I was wondering if anyone has done an install on these yet and if its any different than the LG Pro's.
Old Mar 3, 2006 | 07:54 PM
N2O4YOU's Avatar
N2O4YOU
Installed yesterday. I used one of the how-to's found hear for the Pros. I did not need to pull the starter or passenger valve cover.
Old Mar 3, 2006 | 10:34 PM
Shane_S's Avatar
Shane_S
Since the only real difference in the design of the header itself is the slightly different collector then install should be virtually similar to the pro's.
Shane
Old Mar 4, 2006 | 11:44 AM
Boo383's Avatar
Boo383
Default which how to?
Which How to did you follow? If it can be done without moving the starter or removing the valve cover I might go ahead and try it myself!!
Old Mar 4, 2006 | 03:52 PM
jhester's Avatar
jhester
http://www.ls1howto.com/index.php?article=29
Old Mar 5, 2006 | 11:38 AM
C52000C5's Avatar
C52000C5
Default Hardware?
Not to hijack, but does this system come with any hardware, such as clamps and gaskets?
Old Mar 5, 2006 | 12:36 PM
108C6's Avatar
108C6
the pros come with all the hardware i am sure the street headers come with it also the ony thing different i did was use stock manifold gaskets ( new ones)
Old Mar 5, 2006 | 12:56 PM
fasthwks's Avatar
fasthwks
The streets came with all hardware but no gaskets, I think I paid $20 for mine for the dealer. The install is easy with these, I did loosen the starter and removed the coil packs, very easy and great fitment!
Old Mar 5, 2006 | 05:57 PM
N2O4YOU's Avatar
N2O4YOU
I used how to from cajundude.
Got headers only(fabbed own 3" x midsection.) Came with o2 adapters and 2 slip connecters to go on collecters. No clamps, gaskets, etc..
Bought the camaro ls1 gaskets from local GM Dealer.
To LG Street series
