What I mean is….my air conditioner doesn’t blow very strong in one position, hardly any air comes-out, all other setting work okay. Has any one experience this?
What position is that?
You have an automatic climatic control unit or a manual unit?
You should have a temeprature contol, a fan speed contol, and a directional control. you should also have an inside air and outside air setting.
It doesnt blow in any of the fan speed settings?
we need more info
I have the manual type, not the dual zone. When I place the fan in position one, hardly any air blows-out. Other than that the air conditioner works fine, all the another positions work fine. I remember that on my 81 vett I had a similar problem, the high on the fan would stop working, this was caused by a connector in the engine compartment burning, I would replaced the connector and the fan would again…just thinking this might be a similar problem ...thanks
From: ================ From Toronto ================ 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I have the same problem in my 98. The lowest fan speed doesn't work but all other speeds do. I've been told it could be the "Blower Control Module", could someone please chime in and confirm this for us. Thanks
