Bolt Length to Lower Rear
Old Mar 4, 2006 | 12:02 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Default Bolt Length to Lower Rear
What is the length and diameter of the bolts needed to lower our Vettes lower than on the stock bolts
Old Mar 4, 2006 | 03:13 AM
Pizzano's Avatar
Pizzano
7"/8" (1/2"-13-8")grade 8
Old Mar 4, 2006 | 10:46 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
oem nuts won't work w/ the sae threads, get those also
Old Mar 4, 2006 | 11:33 AM
Pizzano's Avatar
Pizzano
most of the lowering kits come with the nuts, but if your going to just get the bolts, yes get the nuts and washers also.
http://www.boltdepot.com/
this is were I just order my set $12.50 for the set, click on Hex bolts, then the grade 8 1/2''-13 sizes.along with the grade 8 nylon lock nuts, and washers.
To Bolt Length to Lower Rear
