Injectors
Old Mar 4, 2006 | 03:55 AM
JACK EPPERSON's Avatar
JACK EPPERSON
Default Injectors
WHERE CAN YOU GET NEW INJECTORS. AFTER MARKET IS WHAT IAM LOOK FOR,AND WHAT SIZE.
Old Mar 4, 2006 | 10:27 AM
stano's Avatar
stano
What size are you looking for??
Any of the vendors on this forum can help you out. I may have a set depending on what size you need. PM me for info.
Old Mar 4, 2006 | 04:03 PM
TXNC5's Avatar
TXNC5
What are your needs or HP goals? If you know your HP goal, then use this formula:
(HP x BSFC) / (# of Injectors x .8)
This will yield a per injector flow rate in LBs/HR
HP = your desired HP you need to support
BSFC = Brake Specific Fuel Consumption
.8 = represents 80% duty cycle
Old Mar 6, 2006 | 04:07 AM
JACK EPPERSON
THANKS ,I DO NOT KNOW WHAT SIZE I HAVE. I WAS THINKING ABOUT 2LB HIGHER THEN STOCK.
Old Mar 6, 2006 | 06:37 AM
WKMCD's Avatar
WKMCD
Your car has 28.8 injectors now if they are stock. Ford "Red Tops" are rated at 30lb but run about 37-38 (I believe) at C5 fuel pressure.
The question is "Why do you need bigger injectors?". The 28.8's will support up to around 425 RWHP.
To Injectors
