MAFT mounting Location needed
Old Aug 12, 2001 | 11:35 PM
chuckster's Avatar
chuckster
Default MAFT mounting Location needed
I need to mount this where it won't be subject to heat soak. Anyone have a location and mouning tips? Also I tried 3M double sided tape on the the radiator cover. It would not adhere even after cleaning with alcohol.
Old Aug 13, 2001 | 12:07 AM
Bluvette1's Avatar
Bluvette1
Default Re: MAFT mounting Location needed (chuckster)
I mount them in the same place as you had yours with the 3M double face foam tape and never have had a problem. Try it again make sure you clean it good with alcohol.
Old Aug 13, 2001 | 01:36 AM
team-zr1's Avatar
team-zr1
i use velcro type of tape on left side of shroud and it holds up fine.
I wanted velcro since it doa a lot of test/tunes and wanted it to be real easy to pull off. make changes and re-install.
John
Old Aug 13, 2001 | 03:10 AM
adamsocb's Avatar
adamsocb
Mine is attached with Velcro, to inside of the frame rail on the driver's side. I tried it on the plastic shroud and the Velcro tape would not stick to the plastic. No problem since I moved it to the metal frame.
I will post a pic for you tomorrow.
To MAFT mounting Location needed
