Need new battery
Old Mar 5, 2006 | 12:20 PM
98_corvette's Avatar
98_corvette
Default Need new battery
I'd like to buy a new battery, please recommend the best brand/kind.
Old Mar 5, 2006 | 12:28 PM
cliff_ford's Avatar
cliff_ford
All the experts here say Optima Red Top. I got one the other day.
Old Mar 5, 2006 | 12:35 PM
DAN01's Avatar
DAN01
Just put in the Optima red top in my 2001 coupe. Best battery on the market for your vette.
Old Mar 5, 2006 | 12:38 PM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Who sells the Optima? How much? Which model?
Old Mar 5, 2006 | 12:48 PM
DoubleZ06's Avatar
DoubleZ06
Autozone, Advance etc. Check out their website to search for a dealer near you. I believe it is a 75/35 model for $109.
Old Mar 5, 2006 | 01:34 PM
RubberBill's Avatar
RubberBill
Gratias!!!!
Old Mar 5, 2006 | 02:01 PM
tiojames's Avatar
tiojames
Default Battery
A lot of forum members buy the optima series and there are posts from some forum members about trouble with them. I would suggest buying the type of battery that has served you well in the past. I would also recommend getting the side post to top post cable adaptors and buying a top post battery such as came in the 04 vette. Stops all the loose side post problems.
Old Mar 5, 2006 | 02:10 PM
cliff_ford's Avatar
cliff_ford
I’ve been contemplating converting to using the Optima’s top posts. Who supplies the converters? Thanks.
Old Mar 5, 2006 | 02:53 PM
2KFRC5's Avatar
2KFRC5
Aren't the side terminals directly connected to the top posts?
http://www.optimabatteries.com/publi...e/starter.html Click on the cutaway.
Old Mar 5, 2006 | 03:06 PM
cliff_ford's Avatar
cliff_ford
Yes but I think the theory is that the cables are a strain on the side post causing the leaking.
Old Mar 5, 2006 | 03:11 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Don't forget-----experts have been know to be wrong. Optima Red Top, you couldn't give me one for free.
Old Mar 5, 2006 | 03:14 PM
Speed Trap's Avatar
Speed Trap
Several recommend the Exide Orbital battery. Kragen sells it for about $130.00.
Old Mar 5, 2006 | 03:34 PM
cliff_ford's Avatar
cliff_ford
Pray tell your saga.
Old Mar 5, 2006 | 04:02 PM
2KFRC5's Avatar
2KFRC5
There are no side posts. The side terminals are an extension of the top posts. They do not protrude through the case.
Anyway, that's what it appears to me.
Old Mar 5, 2006 | 04:13 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I went with another delco battery, the previous one lasted over 5 years.
and I never had a problem with a delco battery.
Old Mar 5, 2006 | 04:57 PM
triblk6spd's Avatar
triblk6spd
i have owned 5 optima red tops in 5 cars in the last 4 years and have never had a problem. ever.
Old Mar 5, 2006 | 05:02 PM
Oldvetter's Avatar
Oldvetter
I bought the Exide Orbital battery from SAM's. It's $95 or $110, depending on the size. It is an AGM battery. It has the best warrenty.
To Need new battery
Old Mar 5, 2006 | 05:31 PM
cliff_ford's Avatar
cliff_ford
Well I have no argument with you. I’m just going with what I’ve seen on the forum.
Old Mar 6, 2006 | 12:55 PM
GUSTO14's Avatar
GUSTO14
Tom,
Like you I have only had good service from Delco batteries in my Corvettes for almost 40 years. Unfortunately I personally know two folks that have had their Delco's leak since 2000. One was a Tahoe and another was a C5. Both of them caused damage, the C5 was expensive to fix. I still have Delco's in my other Corvettes, but in my C5 I am using an Orbital. It just isn't worth the risk to me. (I am also checking my Delco's more frequently than I ever did before!)
Because of the C5's battery location I think it's a roll of the dice… and I'm not much of a gambler.
Good luck regardless… GUSTO
Old Mar 6, 2006 | 02:03 PM
'95 JWG's Avatar
'95 JWG
Two bad Red Tops in 1 year. None for me.
