Modifying the lower end of a vortex
Old Aug 13, 2001 | 11:49 AM
Alesnik-MD's Avatar
Alesnik-MD
Default Modifying the lower end of a vortex
I have read a number of times that the area below the radiator shroud and in front of the radiator is NOT a high pressure zone even at speed. As a result, intakes like the vortex are not true ram air systems. I do not know if this is true or not, nor do I have any idea on how to determine the pressures at speed in the front of the car. If this is true, however, I should be able to fashion a piece of plastic to the scoop of my vortex (below the radiator shroud) to extend to the lower edge of the front fascia (just below the license plate area). The idea being to "snow-shovel" the oncoming air from an obvious high pressure zone and channel it into the vortex. I realize this would have to be temporary because of the stealing effect it would have from airflow through the front of the radiator, not to mention water ingestion during rain storms. I would expect there to be some net power increase. Has anybody tried and tested an idea similar to this? I know the MAF and throttle body have a theoretical limit to the air flow it will accomodate, and this is more than ample flow for stock/lightly modded engines. How can I measure airflow under different test conditions at home? (without a Ph.D. in engineering)
Old Aug 13, 2001 | 11:59 AM
chuckoc's Avatar
chuckoc
Default Re: Modifying the lower end of a vortex (Alesnik-MD)
The effects of ram air are so minimal I am not sure it would be of any benifit to bother, granted we have to open up the air intake from the stock version, but to go on and try to RAM AIR does not help out of the hole, and prob. not until 80 and above MPH so whats the point? If it is only 1/4 HO or if it is 10 HP I suspect it is in the fractions that it helps if at all, so I say why?
Old Aug 13, 2001 | 12:52 PM
ncvetteman's Avatar
ncvetteman
The setup you explain is similar to the MTI Air Intake, and it does not perform any better than the current systems similar to Vortex. The area under the shroud does get a lot of air, I'm sure you can see trash piled up at the top of the radiator...evidence that there is strong airflow up there.
Old Aug 13, 2001 | 07:09 PM
Mystery Fan's Avatar
Mystery Fan
Default Re: Modifying the lower end of a vortex (ncvetteman)
I changed to the MTI Ram Air and when taking out the original radiator shroud it looked like a birds next at the top of the radiator. It probably wouldn't hurt to check and clean this out from time to time.
Old Aug 13, 2001 | 07:14 PM
ChrisTinaBruce's Avatar
ChrisTinaBruce
Default Re: Modifying the lower end of a vortex (Mystery Fan)
How about ducts into the Vortex, like these?
Old Aug 13, 2001 | 08:17 PM
Sir Sel's Avatar
Sir Sel
Default Re: Modifying the lower end of a vortex (DallasC5)
DallasC5
Looks ingenious :yesnod: Did your modification gain you any HP?
Old Aug 13, 2001 | 09:41 PM
Alesnik-MD's Avatar
Alesnik-MD
Default Re: Modifying the lower end of a vortex (chuckoc)
Chuck, Who said anything about only the quarter?
Dallas, that is a nifty idea. Does it make a difference over the stock vortex unit?
[Modified by Alesnik-MD, 7:44 PM 8/13/2001]
To Modifying the lower end of a vortex
