Need help!! Window adjustment Question
Old Aug 13, 2001 | 02:37 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Need help!! Window adjustment Question
when I roll my driver window all the way down, it hits the bottom with a big "thump". It also rattles when driving if left all the way down (I usually pull it up about 1/2" from the bottom and it no longer rattles in that position). How can I remedy this problem (how do you adjust it to fix the problem?) Thanks...
Old Aug 13, 2001 | 08:31 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Need help!! Window adjustment Question (OliverM5)
If you remove the door panel,you can adjust the window height were the glass attaches to the window regulator,it is slotted...After raising the adjustment up 1/2 in your case,then you will have to adjust the bumper stops (at the same location) to compensate for the position of the glass when it is in the up position...
