bfg drag et tire psi
Old Mar 8, 2006 | 01:44 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
Default bfg drag et tire psi
going to the tract tonight .. what psi shopuld i use? .. zo6 6 speed. figure its going to be about 35-40 degrees out.
Old Mar 8, 2006 | 03:54 PM
HP_Addict's Avatar
HP_Addict
bfg drag radials. start at 20psi and work down from there. I run at 18. Track conditions, temperature, car, etc will all affect the optimium psi.
Old Mar 8, 2006 | 04:22 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
See if you spin or bog & adjust accordingly (up if you bog & down if you spin), providing you launched properly.
Also, RPM's may need to be adjusted with/without adjusting the PSI...
Ron
Old Mar 8, 2006 | 10:39 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I agree with the start at 20 and work down.
Hey you are in the right state for drag racing your Corvette.
Check out the Corvette Challenge at E-tonw this weekend, 3/11
Info at www.corvettechallenge.info/whatisit.php
To bfg drag et tire psi
