Telescopic column retrofit
Old Mar 9, 2006 | 03:56 PM
cadillac jack's Avatar
cadillac jack
4th Gear
Default Telescopic column retrofit
I'm retrofitting a 2000 model column in my 99. Wiring is supposed to plug into the drivers seat control module, but mine says "Telescopic steering N/A" The dealership is no help, as they show only the one module. What am I missing here? Does anybody out there have a part # for what I need? I can by-pass the memory function, and wire it up via a new circuit, but would like to do it right.....?????
Old Mar 9, 2006 | 10:57 PM
Red Vert 02's Avatar
Red Vert 02
Jack, I had an 02 telescoping column installed in my 02 convertible. The column does gets its power from the the driver seat control module. My car did not have the memory option which is needed to power the column so the dealer used seat control module #10435193, he also used harness #12455470 to hook up the column. You will have to have the Body Control Module reprogramed to recognize the column or it will not work no matter what you do. If I remember correctly the BCM is changed from 001 to 002. I don't know if this info pertains to your 99. Hope this helps. Good luck on your install.
Larry
Old Sep 9, 2013 | 04:01 PM
gr8-78's Avatar
gr8-78
Cruising
Default What's The Buzz Jack
Hi CJ;
How did your telescopic install work out?
I just just picked up a power telo column from a 2001 and planning installing in my 1998 coupe. I have auto memory option for seats, mirrors, radio etc:
Any input Would be Greatly Appreciated...
Any other member input is welcome!
Old Sep 9, 2013 | 05:52 PM
gr8-78's Avatar
gr8-78
Cruising
Originally Posted by 8VETTE7
I would not expect any response from CJ any time soon. If you check his profile he hasn't logged on since 9/2/2006.
Thanks 8VETTE7
If I don't here anything from any members,
I will attempt this retrofit soon
I am taking Pic's so I will list a HowTo: if all works out OK
To Telescopic column retrofit
