Need A/C idler pulley info
Old Mar 9, 2006 | 09:59 PM
vetterlatethannever's Avatar
vetterlatethannever
Default Need A/C idler pulley info
I have the ider pulley on the A/C system off on the car right now. I am ordering the part tomorrow and need to know if the front and back 'covers' come with it or are they separate? If so the dealer couldn't find the part numbers for them, any idea?
Thanks!
Joe
Old Mar 10, 2006 | 12:30 AM
vetterlatethannever
TTT!!
Also the pulley part number would be great, just to make sure the dealership is getting me the right part!!
I searched and found a lot of info but no part numbers.
Old Mar 31, 2006 | 09:27 PM
vettman6's Avatar
vettman6
Thanks!
Joe
Front and rear covers come withpulley
Old Mar 31, 2006 | 09:30 PM
vetterlatethannever
Thanks, picked it up last Friday and installed it Monday. Rather simple install and no more squeaking!!!
Old Mar 31, 2006 | 09:51 PM
tsts's Avatar
tsts
Default Idler pulley replacement.
Wish I had read this before you purchased your idler assembly. The stealership will not sell you just the idler wheel for the assembly but will sell you the whole assembly (about $86). What I did was order just the idler wheel, (not a tensioner, the one not on an assembly $22), remove the idler wheel from the a/c idler pulley and put the new wheel on (exactely the same). If you actually need the whole assembly (because the tensioner spring is weak) then you get the whole thing. They won't tell you this. Outside part suppliers don't carry much, NAPA charges more for just the wheels and usually don't stock 'em.(can you believe someone actually has higher prices than the stealership)
To Need A/C idler pulley info
