Trans leaks
Old Mar 11, 2006 | 08:10 PM
USAFPILOT's Avatar
USAFPILOT
Default Trans leaks
I sprung a leak between the trans and differential, maybe also a slight leak at the input from the driveshaft. Can someone point me to a thread explaining how to fix this. The car is a 98 6spd.
Also, can someone give me an approximate amount I should pay to have this job done.
And, can someone let me know what it would cost to do this myself, I know the seals are cheap, and my labor is free, but how much for tools and what do I need?
Old Mar 11, 2006 | 08:48 PM
davey1's Avatar
davey1
both common problems . had left axle cover leek gm has updated parts for that problem .output shaft oil seal p/n 88996703, and the new differential side cover O-ring,p/n 89047953.both available at gmpartsdirect.com. good luck.
Old Mar 12, 2006 | 01:30 PM
jjcslynn's Avatar
jjcslynn
This is not an easy job to do. The side half shaft is easier and can be done on jacks, but the rear diff removal is best done on a lift (some have done it on jackstands though). You have to remove the exhaust and rear carrier. I'd recommend you get the GM manual and a few friends to help you out.
Old Mar 12, 2006 | 03:09 PM
USAFPILOT's Avatar
USAFPILOT
Does anyone know where I can order the GM manual? And does anyone know what special tools I'll need? I figure if the price for the tools is less than the labor to get it fixed by GM...I have all the time in the world to get it done.
Old Mar 12, 2006 | 10:44 PM
jjcslynn's Avatar
jjcslynn
Got mine off Ebay.
Old Mar 12, 2006 | 11:08 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
if it's not a side cover leak(no need to drop carrier)then this will get the carrier out http://www.cajundude.com/differential2.htm
no special tools, trans jack helps, call Fred Beans for a shop manual
Old Mar 13, 2006 | 12:02 AM
USAFPILOT's Avatar
USAFPILOT
Who is Fred Beans? Have any more info...phone # etc.
Old Mar 13, 2006 | 12:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Fred Beans is supporting vendor.
They are loctaed in PA. Phone# 610-495-1800.
Old Mar 13, 2006 | 01:00 PM
USAFPILOT's Avatar
USAFPILOT
I caved...car is at the dealer. My wife wouldn't let me "destroy" the rearend of the car in my garage. Probably best. I need to go to mechanic school. I think it would pay off more than my college education. hehe
To Trans leaks
