Rear gear installation
Usually you just buy the entire rear differential assembly with 3.90s-410s etc. and swap it out. It's a 6 hr. job in it itself. I've done 4 of them and it's time consuming but not difficult.
The 4.10 ratio is a great gear for a 6spd Vette. It really wakes the car up and is only turning about 2100 rpm at 75mph while delivering about 25mpg.
You can get a complete 4.10 diff. from DTE for $1300 and sell your old 3.42 unit for $500. Probably the best $700 mod going
I definitely agree with jmzvet. I recommend getting 4.10’s from DTE. Don’t waste your money with the 3.90’s as it is a so called compromise that you really don’t need. I also suggest you spend a little extra for the hardened driver’s side output shaft for $1,549 plus shipping. This is exactly what I did and it makes your car an entirely different animal. I have not noticed any difference in mileage, as now 6th gear is useable. The only regrets I have is that I did not get the transmission brace, since it is just a little more work when changing out the differential. You may not need the brace unless you plan to do some serious drag racing and/or using drag radials. By the way, once you change the differential, you will need drag radials to hook up. Don’t let anybody tell you that this brand or that tire designed for the street will hook up well. IT WON’T!!!
Good luck,
Clayton from Las Vegas
What do you plan on using your car for? We like to build the differential to what you need and not overkill so it will also not break the bank. DTE sells the diffs the same way we do (Zip) it is not $1300, it is $1300 plus a $500 core charge. You cannot even buy all of the parts in the rear for $700. I can either build your differential or send you out one on a core charge. Depending on what you are doing with it, you may not need the HD axles. Customers sometimes overkill there differential with parts that usually will not break unless they are under severe stress that their cars will never produce anyways. We build allot of race only differentials, and many times we have been in a jam where we had to use a stock axle (the customer knew) because of a time constraint. This particular car puts over 550 hp to the rear wheels and sees speeds over 160mph and it was not an issue. I have a 4.10 in stock that is ready to ship, if you have any questions please do not hesitate to call.
Justin Abbott
Zip Products
