Vararam without a filter??
Old Mar 13, 2006 | 03:06 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Vararam without a filter??
Someone in my corvette club said that when he runs at the strip, he removes the filter on his Vararam. At first I thought he was crazy , but then I started thinking that maybe for just several ¼ runs it would be OK. He claims it adds 2 mph to his trap speed, although he didn’t say anything about his ET. What do you guys and gals think? Safe for a few runs, or looking for trouble?
Thanks,
Clayton from Las Vegas
Old Mar 13, 2006 | 03:46 AM
Z06-Goose's Avatar
Z06-Goose
Thanks,
Looking for trouble. There are other ways to safely add 2mph to yourtrap speed, it may be more expensive to do it, but not as expensive as risking what a small rock into your engine could do. For some people 2mph more may be important, so you never know the things people do to get it.
-Goose
Old Mar 13, 2006 | 06:42 AM
shurite44's Avatar
shurite44
I would just run the original foam filter at the strip instead of the new ones vararam is using. I don't think taking the filter out would give you much more flow than the foam filter. And it will provide protection against any catastrophic ingestion.
Old Mar 13, 2006 | 08:47 AM
rws.1's Avatar
rws.1
IF I recall correctly, VaraRam had 3 different foam filters with one made specifically for the track...
Old Mar 13, 2006 | 09:33 AM
DPG's Avatar
DPG
St. Jude Donor '06
You have to ask yourself, whether 2mph is really worth it at the track when you pretty much race for fun. It wont be much fun when you suck something into your intake
Old Mar 13, 2006 | 09:36 AM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Not to mention all the crap in the unfiltered air (dust, etc.)...
Old Mar 13, 2006 | 10:14 AM
Z06-Goose's Avatar
Z06-Goose
Hmm?! never heard of a third filter. I know they have the original filter they came with, and then the green one later on. Can you provide more info on the mentioned 3rd filter?
-Goose
Old Mar 13, 2006 | 10:54 AM
usd2sing's Avatar
usd2sing
i've seen guys remove the filter at the track. said it picks up 1-2mph. asked about ingestion concerns, was told rocks, pebbles, paper, etc isnt getting passed the maf screen.
i wouldnt do it...want nothing to do with calling a flatbed to haul me home from the track..
foam filter isnt much of a filter, but i check it after every event, no debris to speak of..throttle plate is always clean.
just FYI
EDIT: plus if your run the screens (z06 screens) up front not much other than some dust should get passed them.
Old Mar 13, 2006 | 11:17 AM
tiojames's Avatar
tiojames
Default filter
I think at WOT I would pass on removing the filter. You could suck in a lot of sand particals in just a few runs. Ultimately you are doing what the filter was designed to stop.
Old Mar 13, 2006 | 11:26 AM
Z06-Goose's Avatar
Z06-Goose
just FYI
I haven't seen a Z06 MAF Screens, but if the ones I've seen on f-bodies is an indication, I would say it's still too big for protection. A small rock can do some damage, an even smaller debris will do just as much damage as it's the type of things that can get wedged between the piston and the cylinder wall.
-Goose
Old Mar 13, 2006 | 01:13 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Thanks everyone,
I think I will leave the filter in. Had to ask.
Thanks,
Old Mar 14, 2006 | 06:18 AM
DoubleZ06's Avatar
DoubleZ06
Wise choice.
To Vararam without a filter??
